February 18, 200818 yr I am looking over the Blueprint BP1004 Hofi Woop Tongs, and I have a question. He gives the starting length and the tong jaw bend dimensions for the 2" tongs, but what are the dimensions used for the 1" and 1.5" tongs? I find myself needing some good multi-purpose tongs, and this looks like the one.
February 18, 200818 yr R/O=% reproduction size divided by original size equals percentage 50 cubits divided by 4000 cubits = 0.125 or 12.5% reduction 4000 cubits divided by 50 cubits = 8.00 or 800% enlargement 1.5" / 2" = 75% reduction or 0.75 employing that number times any other dimension at the original scale, 9" long x 0.75 = 6.75" in scale, for arcs employ radius or diameter measurements for a reductionenlargement as to how ergonomic or mechanically applicable a direct scaling might be...... Id imagine some aspects should be scaled and others remain basically the same (though an overall scaled dimension of 75% might suit a child) when it comes to drawing out a dimensioned stock it gets even more interesting while 12" stock is twice as small dimensionally than 1" stock, its one quarter as much mass to move around which of course effects the length you'd produce for a given shape, so while it would remain in scale, mixing dimensions some at the original size and some at the reduction gets complicated or not, just have extra and trim it to size when the results become obvious the main fixed point I see is the rivet which he gives the following dimensionsThe eye. The distance from the Center Punch to the end of Tongs is For # 2" it is 4" For # 1 1/2" it is 3 1/2" For # 1" the steel is 9/16" OD and the distance is 3"
February 18, 200818 yr Bob about 1/4 of the way down Hofi specifies where to punch the eye. That is the difference for different size stock. All else remains the same.
