January 7, 20179 yr Hello all! For your consideration, here is the the blueprint for my Rail Road Track anvil. I am posting this here, one to help find any mistakes in the blueprint and two just in case someone is looking for an idea. Now, before we get back into which way is the proper way to mount a rail, I have two pieces of rail this is for my horizontal mount. The vertical mount design is coming soon.Notes: The 3x4 and 4x4 will be glued together like a butcher block before the 2x4 and 3x4 crowns are added The staggering of 3x4 and 4x4 allow for more surface contact with each board. The 8 lag bolts are to bolt the four 6" 3x4's to the top and bottom This design is not showing how I will be mounting the rail to the stand. Enjoy BP_0002 - RR Track Anvil Stand.pdf BP_0002 - RR Track Anvil Stand.xlsx
January 7, 20179 yr A variation would be to make use of the two different sizes of wood by stacking the 3's and the 4's against themselves and justifying the stacks to one side leaving a series holes on the other side to hold hammers and or tongs
