Sling-it Posted October 8, 2016 Author Share Posted October 8, 2016 Well, according to the bath scale, she came in at 450 lbs! Brick under one side, and scale under the other, read, swap, add the numbers. The horn side came in at 260, the heel came in at 190. There's probably some plus/minus there, but that's pretty darn close. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 9, 2016 Share Posted October 9, 2016 a 3' piece of 2x8 marked off in inches, a brick or wood block the thickness of the scale and a scale should let you figure out a pretty good weight--- place the brick at one end and the scale at the other and the anvil in the exact middle and you should read 1/2 the weight on the scale. Quote Link to comment Share on other sites More sharing options...
