the iron dwarf Posted May 7, 2016 Share Posted May 7, 2016 have a piece of machinery here that has been standing for probably 18 years unused so am going to change all the oils in it but there is one used in the main gearbox and other parts that I cannot find a modern equivalent for. it is in the manual as DIN 51501 N36 LUBRICATING OIL with a viscosity of ca 33c st ca 4,5E 50 degrees C and lists the following ( none of which I can find here ) BP ENERGOL HP20 ARAL CMU OD TU 518 SHELL CARNEA OEL 31 ESSO ESSTIC 50 CASTROL MAGNA HL MOBIL VACTRA OIL HEAVY MEDIUM can anyone suggest a modern equivalent. it is quite an expensive piece of equipment so I dont want to use the wrong stuff Quote Link to comment Share on other sites More sharing options...
wpearson Posted May 7, 2016 Share Posted May 7, 2016 http://www.alexoil.co.uk/bp-pre-iso-iso-lubron-oil-reference-guide_c128.aspx shows a cross for BP ENERGOL HP20 -c Quote Link to comment Share on other sites More sharing options...
the iron dwarf Posted May 7, 2016 Author Share Posted May 7, 2016 Thank you, did not think of slideway oils, looks like a normal bd 68, will check the spec out on some I have Quote Link to comment Share on other sites More sharing options...
yahoo2 Posted May 8, 2016 Share Posted May 8, 2016 BP energol HP 20 became castrol magna 2 this is a spindle oil castrol HL became castrol HL 68, I think it is magna 68 now but cant be sure. I dont deal with either company anymore. Quote Link to comment Share on other sites More sharing options...
