December 27, 200718 yr When I've looked at the knives in here it is always a type of steel 10## It seems like a mild steel. Why don't you use tool steel because it's so tough, other than expense? PLease explain what kind of steel you want when make a knife and why? I am very curious.
December 27, 200718 yr Tool steels tend to be difficult to forge. To get the most out of them often requires soaking at a specific heat during heat treat that is difficult in a coal/charcoal forge. The 10XX series are easy to forge, cheap and with enough carbon (around 60 point or better) makes for an excellant knife. at least that is my view of the world ron
December 27, 200718 yr M Leaf spring is doable, but I have found that a short piece of coil spring is easier to cut and hammer into shape than a chunk of leaf spring.
December 27, 200718 yr So a leaf spring is an example of plain carbon steel that I could use? The leaf spring (assuming it is from a vehicle such as a truck) is probably some sort of alloy like 5160, etc. So, to answer your question, the leaf (vehicle) spring is NOT considered a "plain carbon steel".
December 27, 200718 yr MB, You should throuroughly read and studyhttp://www.feine-klingen.de/PDFs/verhoeven.pdf. Then some of this stuff will make more sense to you. ML
