pike3e Posted November 6, 2015 Share Posted November 6, 2015 I have a 55lb striker hammer (anyang style), with the top die stuck in the up position. I had a stuck die and was hammering out the key and it must have moved a bit and when I turned the hammer on the tup is stuck inside the body of the hammer. Anyone know how to get it back down? Link to comment Share on other sites More sharing options...
phabib Posted November 8, 2015 Share Posted November 8, 2015 I have never done this, or worked on one of these hammers so give my opinion the appropriate weight. My guess is that you need to remove the head cover on the tup and tap the piston back down. You may want to loosen the bolts that hold the bottom seals in place so that you're not forcing things, and then re-tighten them after the piston comes through. James Johnson has some You Tube video showing how to remove and replace a piston that look like a great guide to the job. Link to comment Share on other sites More sharing options...
ironwolfforgeca Posted November 9, 2015 Share Posted November 9, 2015 Yep pretty much what ph said I had to pull tub out of a #33 yang I had an air Leak & though piston ring was broken Hence the Noise I was hearing replaced seal fix -- noise ended up being motor mount tightening bracket the noise transferred to front of hammer ended up going from one end of the hammer to the other cking Everything pulling off all covers cking all seals & bearing just to find that noise well short story I Know how the hammer is built now LOL Link to comment Share on other sites More sharing options...
Wroughton Posted November 19, 2015 Share Posted November 19, 2015 So, how'd it go? Still stuck? I've done the same trick. It will score the flat sides on the guides but you've already done that so...... put a little pressure to the treadle and see if that kicks it out. The flat plates on either side of the cylinder are replaceable if its like mine. I've stuck mine this way a couple of times but usually its just a copper shim plate working its way out from behind the die. It may groan and spit oil but usually kicks out after a stutter or two. You can turn your plates around if they're scored bad. If that doesn't work you might try smacking the die the opposite way with something. I know it disappears up in the cylinder housing but you may be able to hit it (sending the die AWAY from the side the key is sticking into) with a big (BIG) punch. If it's loose from the key coming too far it might just fall out and drop the tup. I've had my Stryker for 11 years and I'm more than pleased with the capabilities of this little hammer. The oiler's crap and the factory die keys are too but it's basic message gets put to the metal very well. I'm chronically breaking down stock way bigger than the recommended 1" max size. Link to comment Share on other sites More sharing options...
pike3e Posted November 20, 2015 Author Share Posted November 20, 2015 I took the top off and banged it with a wood block and it didnt move. I took the bottom ring off and this caused the ram and the ring to drop down. I was able to tap the ring off with a brass hammer. I then removed the stuck die with a drift and some hard hammer blows and then put it all back together. Tapping harder from the top would have worked just as well but I wasnt sure how hard to hit. Link to comment Share on other sites More sharing options...
Stormcrow Posted November 21, 2015 Share Posted November 21, 2015 Glad you got it sorted. Any damage to the machine? Link to comment Share on other sites More sharing options...
pike3e Posted November 22, 2015 Author Share Posted November 22, 2015 Does not appear to be any damage. I forged some 416/1095 laminate today and everything seemed fine. Thankfully. Link to comment Share on other sites More sharing options...
Please sign in to comment
