Braddock M. Posted July 24, 2015 Share Posted July 24, 2015 Alright so I made a thread a while back when I started but it disappeared a few months ago, I took all your tips and modified it a bunch and now I'm pretty much done.So its half a 55gal drum on a generator cart with a big shop vac and variable router speed controller, with some tables for tools. I've got a fence post(i know about the galvanized hazards) tuyere which I moved up 3 inches from the bottom where I first had it.And I just finished laying my mixture of 6:5 sand clay. I added a few access points as well. I trade to lay the refractory in a trench design with a bowl in the middle as my main forging area. I plan on plugging trench holes most of the time. I like the idea of forging machetes so the full length will be good for heat treating I presume.It looks deep right now but my clay is pretty moist and will shrink about a half inch I'm sure. Does it look decent so far? Looks like it'll be a good charcoal forge? Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted July 24, 2015 Share Posted July 24, 2015 I used a metal cylinder on a metal "ramrod" to control the length blown on my long forge I built back in 1981. Slipped in in from the end opposite the blower; easy to use and easy to clean out the tuyere . Quote Link to comment Share on other sites More sharing options...
Braddock M. Posted July 26, 2015 Author Share Posted July 26, 2015 ive thought about that, cant isolate the middle that way though Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted July 26, 2015 Share Posted July 26, 2015 Sure you could, the blower would just hook into a pipe going to another cylinder with a hole through it so you could adjust from either/both end(s). Quote Link to comment Share on other sites More sharing options...
