Grundsau Posted October 30, 2014 Share Posted October 30, 2014 Read through Brian's crane tutorial and also watched a nice crane forging vid by Alec Steele on YouTube so figured I'd give it a try. It's made from 3/16" x 1" stock. I don't have a hot cut chisel and the feather didn't turn out well. Next time I'll bandsaw cut that part and spread it hot. Tried using a hot cut hardy but that didn't work so well. Not sure how you keep the ring from distorting when chiseling the feather. Will try a wing when I can scare up some fullers. Quote Link to comment Share on other sites More sharing options...
matto Posted October 31, 2014 Share Posted October 31, 2014 Looks good for a first try. Remember you are a blacksmith adapt and over come. You have any of the flat stock or 3/8 or 5/8 square stock? Mild or other, then you could make a quick hot cut chisel. You are cutting thin mild HOT stock a mild steel hot cut chisel will work. What ever it takes to get the job done. Quote Link to comment Share on other sites More sharing options...
Grundsau Posted October 31, 2014 Author Share Posted October 31, 2014 Matto, thanks for the reminder. I have some 3/16 flat in 5160 and will try that also. Quote Link to comment Share on other sites More sharing options...
