First forge finished
Slayer63
What's the ambient?  Also the smaller "bbq tanks" are known to sometimes have problems with their flow checks---mandated so that it shuts the gas off in an "unconstrained flow" situation---well a forge burner can look like that if you turn on the gas fast.  Bigger "commercial" tanks don't have them.
May want to try the smaller tank again and slowly open the tank valve.  If still having problems---well a tank exchange can sometimes help---make sure the one you get has a good date stamp; because re-fills are cheaper than swapping!
