large Lawnmower Blade Knife
Hello, and happy Fathers Day.
Here is another knife I made using another lawn mower blade, it is the knife at the bottom of the picture.  The top knife is one I had posted before. I used most of the blade the holes are where the blade attached to the lawnmower.  The blade is over 10 inches long and  3 inches wide, and the handle is 4.75 inches. I used purple heart for the wood on the handle.
I polished it to a mirror finish, you can seen my hand and camera in reflection.
post-22169-0-55772600-1371356717_thumb.j
post-22169-0-72258600-1371357483_thumb.j
PoundHound
Thanks
I have to get better at the polishing. I don't have a belt grinder which can do a lot of the work for me. But I do have an orbital sander which i have pads up to 220 grit. then hand sand from there.
I am starting with a pretty uneven surface, since the lawnmower blades are used they have a lot of dings in them which I grind out.
PoundHound
