Champion Blower Restoration finished.
Robert_t
Well it took a lot longer than I thought it would but here are some before and after shots. I replaced all the screws as all of them where in very rough shape. I cut a new depth screw to replace the damaged one. I had to cut a new 1/8th inch key for the gear on the shaft attached to the handle also had to file out several rough spots on the shaft as when it was "fixed" before they just forcibly screwed the set screw into the key slot on the shaft :angry:.  Cut me some leather gaskets turned a cedar handle painted and put it all back together and bam ready for another 20 or 30 years of work :D.
post-31826-0-66640800-1367612181_thumb.j
post-31826-0-14009800-1367612202_thumb.j
post-31826-0-83463500-1367612246_thumb.j
post-31826-0-60059100-1367612323_thumb.j
