Wroughton Posted April 29, 2013 Share Posted April 29, 2013 I have some chain from an Esco paddle chain for carrying away wood chips and bark. Normally I would just heat it up and put it under the hammer to see what happens. I'm sure its going to be "obstinant" to say the least. Any thoughts? The links are about 10" long x 5" wide and 1 1/8" in diameter Quote Link to comment Share on other sites More sharing options...
HWHII Posted April 29, 2013 Share Posted April 29, 2013 Those types of metals are usually used in high temp and corrosive applications and they are hard. Did it come out of a paper mill? Quote Link to comment Share on other sites More sharing options...
Wroughton Posted April 29, 2013 Author Share Posted April 29, 2013 The chain came from a hog fuel storage building. The mill made studs and mostly plywood. The chain ran to the hog fuel boilers. I have a bunch. I have a couple of landscaping projects for some but I'd like some thoughts on what I could be doing with it in the forge, tooling, etc. There are also some quick links. Burly, with a E90** symbol on them. Is that the alloy? Here's the hog fuel building. 60ft tall. The upper catwalk looking thing going in the end was where the chain resided before the demo. Quote Link to comment Share on other sites More sharing options...
Wroughton Posted May 1, 2013 Author Share Posted May 1, 2013 A few pictures of the chain. Quote Link to comment Share on other sites More sharing options...
Wroughton Posted May 1, 2013 Author Share Posted May 1, 2013 hmmm :wacko: The chain, and a peak at a quick link. They read E-9710. Quote Link to comment Share on other sites More sharing options...
oddtodd Posted May 2, 2013 Share Posted May 2, 2013 You are going to work your butt off with that. lol I'm just starting and I can tell that. I don't know anything about steels yet though. That's some big chain! Quote Link to comment Share on other sites More sharing options...
Wroughton Posted May 13, 2013 Author Share Posted May 13, 2013 Sent an email to the supplier. Hi Darin, Thanks for your email and I hope I can provide you enough information for your use of these castings. The loop chain is made from Hadfield manganese which is a work hardening steel used most in applications where there is repeated impact to generate a hard surface while maintaining a strong ductile core. Think of crusher parts and liners for ball mills. If the material is heated beyond 600 deg F it will become brittle and weak. After any hot working of the material it must be heated to 1900 deg F and quenched in water for it to become strong and ductile again. Initially it will only be around 250 BHN hardness but as the surface is impacted it can harden up to 550 BHN. The other castings are 8630 alloy steel in a normalized condition. This material can be hardened to around 400 BHN to provide good strength and hardness. Best regards, Matthew De Steur mdesteur@nordstrongequipment.com Technical Sales Representative Office: (604) 882-1602 Fax: (604) 882-1603 Cell: (604) 839-1402 Unit# 205, 9710 - 187 Street, Surrey, BC, Canada V4N 3N6 Anyone with info/experience on forging Hadfield manganese? I had some success with a small pry bar but then had a chunk come completely apart after breaking it down some. I was tending towards the high temp side. Hot short? Wikipedia answered my question. http://en.wikipedia.org/wiki/Mangalloy Quote Link to comment Share on other sites More sharing options...
