danguite Posted February 25, 2013 Share Posted February 25, 2013 I have been working on building a coal forge slowly, but after getting a nice bonus from work I decided to jumpstart things a bit by buying a gas forge. I bought a two burner Metalsmith model from Diamondback Ironworks and it got here this week. First start: First metal being heated: I just wanted to play for a bit this time: So it worked great. I still have to figure out a proper fuel solution, as you can see I'm just using a 20lb tank for now. I also didn't want to run for too long before I get a CO detector. How does it look? Quote Link to comment Share on other sites More sharing options...
queensdudleyanvil Posted February 25, 2013 Share Posted February 25, 2013 Looks really nice. I've done the same thinking, solid v gas, build v buy, brand, etc. Decided on the diamondback, just can't decide on the blacksmith or metalsmith version. Want to share why you went with this model? Quote Link to comment Share on other sites More sharing options...
danguite Posted February 25, 2013 Author Share Posted February 25, 2013 I like the versatility of the doors. I might never need them, but I like having the choice. Quote Link to comment Share on other sites More sharing options...
jmccustomknives Posted February 25, 2013 Share Posted February 25, 2013 I've got the knifemaker model. Works pretty good. I make a lot of cable damascus and my "technique" requires using a lot of flux. I never really knew that the borax would eat the ceramic bricks like it would. I started using oil dry (a tip from an old 'smith) in the bottom and that works well. The biggest drawback to the knifemaker is how small the work has to be. Quote Link to comment Share on other sites More sharing options...
danguite Posted February 25, 2013 Author Share Posted February 25, 2013 I'm have a bit of time before I attempt any welding, but thanks for the advice. I got the doors to try and get around the possible size issues. I have no idea what I'm going to be making, so I just want to be ready for as much as possible. Quote Link to comment Share on other sites More sharing options...
56FordGuy Posted March 1, 2013 Share Posted March 1, 2013 I have the Blacksmith version. Almost went for the Metalsmith, but decided to use my coal forge for anything too large or awkward. Keep us updated on how your forge works out for you. I've burned through two 100 lb tanks with mine, it's had a few small hiccups so far but nothing too bad. Quote Link to comment Share on other sites More sharing options...
