my first built forge
Parrothead
I started with firewood in a wheelbarrow, then coal in a stack of firebrick. After getting tired of spending my precious playtime getting ready to play I assembled this thing. Nothing orginal I can take credit for, just a lot of time looking at what others have done.
The only purchased materials in this are a piece of pvc pipe and a fence top cap. Everything else was salvaged or found on side of the road.
Ok, where my pics??
Im at a loss. Ive downsized the pics and still no upload.
When doing upload, did you click on area of uploader bar that is in Yellow circle...
This should of been second screen of upload process.....
Try to go back and edit original post (using FULL Editor)  to see if "Attached Files" are still available to "Add to Post"...
post-29850-0-90294700-1359475988_thumb.p
Dale
Here is the almost complete forge. Needs a little tweeking yet. The plumbing is a corner fence post I cut and welded into a T. My air comes from a salvaged furnace blower. With the bottom missing out of my T its almost just enough air. When I cover the bottom its a little too much air.
  • 2 weeks later...
