lawnmower blade scandi
monkeyboy
here is a roughed in blade cut from a lawnmower blade. i will narrow down the stick tang and re-profile the blade then start on the grind.
this particular piece of steel seems to be very tough, hard stuff.:o
hope it is good steel.
buzz
meant to post a photo. argh
i am starting to understand something here. these mower blades are hard steel.
takes some effort to grind away to pattern and then quite a bit of sanding to take out grinding marks. but, results seem to be good. this blade i've been working on has been sharpened and is a pretty good cutting tool.
time to start the handle process. maybe a brass guard and some nice wood and antler for handle material. choices are many.:D
buzz
rough blade surface. needs more finish sanding. argh.
2679.attach
