NavySWCC37 Posted January 2, 2013 Share Posted January 2, 2013 I looked on NCK for some cheap Micarta, but I found some stuff called Corian. is it a plastic, or a laminate , or a phenol? what is it, is it any good for a full tang? Quote Link to comment Share on other sites More sharing options...
bigfootnampa Posted January 2, 2013 Share Posted January 2, 2013 Solid plastic countertop material. Pretty tough, machinable, polishable... I have seen a few knife handles made of it. Quote Link to comment Share on other sites More sharing options...
ciladog Posted January 2, 2013 Share Posted January 2, 2013 Solid plastic countertop material. Pretty tough, machinable, polishable... I have seen a few knife handles made of it. Corian is not solid plastic. It is made from acrylic polymer (as a binder) and mostly alumina trihydrate which is mineral found in nature. Very tough stuff and needs to be cut with carbide tooling. I worked with if for years back in the day. Quote Link to comment Share on other sites More sharing options...
thingmaker3 Posted January 4, 2013 Share Posted January 4, 2013 http://corian.co.uk/Corian/en_GB/assets/downloads/documentation/corian_specdata_en.pdf You can do inlays or thermoform it. You can also use dyes on it. Quote Link to comment Share on other sites More sharing options...
pkrankow Posted January 4, 2013 Share Posted January 4, 2013 For limited runs common tooling will cut it fine. Block plane, chisel, drills, woodworking tools... It will dull a tool in a hurry, but not in a single cut. Carbide tools are probably desirable for "mass" production. Phil Quote Link to comment Share on other sites More sharing options...
ciladog Posted January 4, 2013 Share Posted January 4, 2013 For limited runs common tooling will cut it fine. Block plane, chisel, drills, woodworking tools... It will dull a tool in a hurry, but not in a single cut. Carbide tools are probably desirable for "mass" production. Phil Very amusing answer Phil. For limited runs > not in a single cut > it will dull a tool in a hurry > [but] carbide for "mass" production. Corian is very hard and very abrasive and chips when cut with dull tooling. I suppose you could cut, sharpen, cut, sharpen, cut, sharpen until you get the job done. Quote Link to comment Share on other sites More sharing options...
pkrankow Posted January 4, 2013 Share Posted January 4, 2013 Very amusing answer Phil. For limited runs > not in a single cut > it will dull a tool in a hurry > [but] carbide for "mass" production. Corian is very hard and very abrasive and chips when cut with dull tooling. I suppose you could cut, sharpen, cut, sharpen, cut, sharpen until you get the job done. I have used corian for some small projects in the past and did not have a problem. One-off projects, drilling several holes, trimming to fit, and rounding the edges. Nothing complex, most were access covers for a boat, some with equipment cutouts. I did not have a chipping problem. The only power tool was a drill. Phil Quote Link to comment Share on other sites More sharing options...
