Pattern welding session at a friends new garage smithy
Did a pattern welding session with a friend that is just starting up and wanted to learn a bit.
Started out with 8 layers (25x24x120 mm), used a large sledge hammer, sure missed the machine hammer. :)
Did two folds (even though only 16 layers are visible in the pics).
Interesting to do welding in ejector gas forge instead of a forced air. The heat areas are a bit different from my own. But it worked really well, and did not use much gas (judging from the ice on the tank (P45) ).
I hope that he will make a nice knife out of the bar that we made.
Here are some pictures:
He will have a nice piece of steel to work with. But he will start out learning to grind on some mild steel first. :)
