Mrhappybottms Posted September 24, 2012 Share Posted September 24, 2012 My newest rebar knife. I got some more rebar knives on the way, and i should be able to start making some high carbon ones soon! Quote Link to comment Share on other sites More sharing options...
switchjv Posted September 24, 2012 Share Posted September 24, 2012 looks good. im currently making a small one too. its made from a stainless 1/2" bolt. Quote Link to comment Share on other sites More sharing options...
Rich Hale Posted September 24, 2012 Share Posted September 24, 2012 Switch before you put too much effort into the ss bolt youi may wish to see if a magnet will stick to it. If not it does not have enough carbon to heat treat and will make a poor blade. If a magnet does stick it still may be tough to heat treat correctly. May wish to rethink what you put so much work into? Quote Link to comment Share on other sites More sharing options...
switchjv Posted September 24, 2012 Share Posted September 24, 2012 Switch before you put too much effort into the ss bolt youi may wish to see if a magnet will stick to it. If not it does not have enough carbon to heat treat and will make a poor blade. If a magnet does stick it still may be tough to heat treat correctly. May wish to rethink what you put so much work into? I thought about that one a bit. However, the piece im making out of it is a small letter opener. Plus the cutting edge is only about an inch long. Quote Link to comment Share on other sites More sharing options...
