The crazy chef forge
So I built the first part of my forge today. Im calling it the Crazy Chef Forge since its made from a wok. No, seriously, its a 16" 14g high carbon steel wok i nabbed from a local restaurant supply for $17, some black iron piping for duct ($8) with that end being PVC so i can tool it a bit depending on what blower i attach (broke the one i had put on there). The end only gets warm to the touch, no worry. The rest is fire brick and refractory mortar i got for under $30. I am working with a friend who has access to a plasma cutter and industrial welding equipment to make a good stand. Im thinking i will put locking caster wheels on it so i can move it around as needed. I have only fired it once but seems to do a smashing job and coal cokes very nicely in it. I will fire it again tomorrow and push it a bit harder and try working a bit with it.
post-26372-0-81008500-1344663798_thumb.j
Nice forge. My first forge was made out of an Hibachi. Welded up a air tube and ash dump, lined it with refractory (as with yours) jamed a wad of chicken wire in the air hole, and forged away. You may have bigger better forges in the future but this one will always be remembered with satisfaction.
Might want a table around it but otherwise that is a sweet setup. See if you can find a discarded sheet pan, or an old steel shelf so you can have some added fuel storage. Cut a hole in the sheet so the wok fits in.
Nicely done!
Phil
Nicely done!
Phil
Thats exactly what i was going to do. Cut a circular hole in a steel full sheet pan and then weld a stand around it with another sheet pan bent/wrapped around one end as a shield and backstop for more fuel. Was only going to make it only about 3 foot tall as i want it to be pretty small and portable. Then i will have to work on a proper stand for my anvil. Which i have cleaned the scale off and painted with high temp engine enamel. Its cherry red and looks badass, haha.
  • 2 weeks later...
I have been working with my new toy a couple times (i have 2 knives im working on i will show later when they are done) and i have learned much both on everything involved. Though a critical critique has come up about my forge that may require a rebuild.... Namely that the fire pot is too deep. While the 7" deep conical shape is extremely efficient at retaining and reflecting heat. I can get 1/4" x 1" stock from room to yellow heat in under 2.5 minutes with it and welding heat about 3-4 minutes. A bit too much air and i even accidently melted one piece i was working on. (live and learn) It also seems to be reasonably fuel efficient as well. With about 15 hours of hard burning on it I seem to have only gone through maybe 10-15lbs of coal. But because the pot is so deep i can only heat about 3" sections of the first 5-6" of a given piece. Good for small knives, but last night i was trying to make some long handle tongs and couldnt get far enough down the metal to heat where i needed to work the rivet section. So i think i will try to make a new one that is a bit larger with a fire pot thats only about 3" deep, flat working surface, and more surface area for coal.
TL;DR Fire pot too deep, will need to redesign.
So add a "fence" that allows you to pile fuel higher with a couple of opposing slots to stick the workpiece through.
