Adze (first atempt at metal working)
Made it from a railroad spike marked "HC". After reading about how the carbon content on spikes is so low I'm really surprised and happy with how sharp the edge is. Making it I figured it would just be a practice piece.
Curious if anyone would have suggestions/analysis regarding the cracking around the hole... not sure if this is due to pounding on it after it was too cool to work, or maybe I got it too hot? Also is there a sure fire way to center the punch up when starting a thru hole? I guess I should have marked it somehow when it was cool..
Looking through the posts here inspired me to actually try and pound on some metal so thanks!
post-25917-0-79029800-1341202488_thumb.j
post-25917-0-52373600-1341202497_thumb.j
post-25917-0-37787700-1341202507_thumb.j
post-25917-0-96366300-1341202519_thumb.j
post-25917-0-12709600-1341202529_thumb.j
jwillhite, carbon content does *not* affect how sharp you can get it---A.G.Russell once flattened and sharpened an aluminum beer can till he could shave with it!
What the carbon content affects is how *long* that edge will hold with higher carbon increasing wear life.
As you get more experience you could always go back and forge weld on a higher carbon pad to make the edge---forge it onto the backside so that the edge will always be the higher carbon stuff till you sharpen it totally away---then repeat.
I have commercially made adzes where the body was made from real wrought iron and a thin pad of Higher Carbon steel was forge welded on to make just the last bit of the edge. (Even as late as the American Civil War HC steel could be 6 times the cost of wrought iron and so was used sparingly!)
Ha shaving with aluminum doesn't sound like it would be fun for very long... I should have been more explicit, after using the adze to carve out wood(soft) for ~30min. I wasn't able to see much change in how sharp the edge was. This surprised me since RR spikes aren't supposed to be very hardenable.
Yepp this is my plan, need to build a better forge first, don't think I can get a high enough temperature with my current setup(see picture below). Maybe if I try MAP gas or something else it would be possible.
post-25917-0-53828900-1341249591_thumb.j
that is pretty good. if you like it stick with it and you could learn alot
Practice makes perfect right, I imagine I'll maintain interest. Wanted to try it out at first due to the high cost of good woodworking tools... now it seems like it may be pretty enjoyable all by itself.
I've welded up billets using charcoal sieved from a fire and a hole in the ground for the forge. Doesn't have to be fancy to get the job done! (I did cheat and use a nice hand crank blower; but I've done the same using charcoal and a bellows in one of my homebuilt forges.
