Blackwaterforge Posted June 16, 2012 Share Posted June 16, 2012 Started with 4 1/2" of 1045 Quote Link to comment Share on other sites More sharing options...
MOblacksmith0530 Posted June 17, 2012 Share Posted June 17, 2012 Nice looking piece. Did you forge the hex or just upset it from hex bar? I have a friend who has access to cnc machining centers and I plan on having him mill me a 2" thick block with a 1-1/4 inch square hole with about a 3/4 radius in it to upset flatters into and was considereing using something like 1045. I haven't decided whether slit the hole for the handle first or not. I will probably try it both ways. I was planning on buying the stock in inch and a half bar form and necking it slightly to drop in the upsetting block and go to town on the face upset. Can't wait to try it out. Quote Link to comment Share on other sites More sharing options...
Frank Turley Posted June 17, 2012 Share Posted June 17, 2012 A suggestion. The central working area of flatters are flat, but in order not to leave edge marks on the work, I have fallen the edges off 2 or 3 degrees with my disc sander and sanding belt. Say you have a 3" square flatter base, about 1/4" to 5/16" is relieved . Years ago, I worked with an older man originally from Mexico, Victor Vera. In Spanish, he called the flatter la plancha, which translates as the clothing iron. In Spain, they call it a martillo aplanador, a smoothing hammer. Quote Link to comment Share on other sites More sharing options...
Blackwaterforge Posted June 18, 2012 Author Share Posted June 18, 2012 Started with 4 1/2" 2" round. A suggestion. The central working area of flatters are flat, but in order not to leave edge marks on the work, I have fallen the edges off 2 or 3 degrees with my disc sander and sanding belt. Say you have a 3" square flatter base, about 1/4" to 5/16" is relieved . Years ago, I worked with an older man originally from Mexico, Victor Vera. In Spanish, he called the flatter la plancha, which translates as the clothing iron. In Spain, they call it a martillo aplanador, a smoothing hammer. Yes The working surface of the flatter is about 2 1/2 Quote Link to comment Share on other sites More sharing options...
