Posted
Well my best friend wants me to make a dagger for his brothers birthday.
A double sided 7" blade dagger made from 1095
Handle will be burned in and wire wrapped.
I plan a simple straight and rounded cross guard.
The neat thing will be a triangular pommel with the triforce etched in :D
Do I know how I'm going to attach that yet? no :( but I'll figure it out!
Here are some pics after I ground and hardened the blade.
post-23440-0-48972600-1327444758_thumb.j
post-23440-0-31562700-1327444765_thumb.j
post-23440-0-51251300-1327444771_thumb.j
Posted
I don't recall Link every carrying a dagger...that means little though.
Are you thinking about making the pommel peened on, or do you have some other idea?
Phil
Posted
Haha well it's just a zelda themed dagger
You know I'm not sure.
I thought about a peen but I just don't see how thats possible in a way that would maintain
a triangular shape.
Unless the triangles point was up.
In face I'm an idiot, don't listen to me, that sounds entirely more sensible than what I had planned.
Yup so there you go, triangle's point will face up and the end will be peened
Posted
I was gonna say either have the triangle point up if you're willing to compromise for simplicity's sake, or use a tap and die set to thread the end of the tang and the drilled hole of the pommel, which would allow you to keep the triangle pointed down.
*edit: Though I guess [using a tap and die set] that this would mean you'd have to shape the lower portion of the tang into a cylinder, or forge weld a small piece of round steel to the very end of the tang.
  • 2 months later...
