olfiar Posted February 18, 2007 Share Posted February 18, 2007 I know this crack is hard to see but its in front of where my thumb is in the pictures. I'm not sure if its fixable but I hope it is. If you can't tell by the pics just tell me and I'll try to get better ones. Quote Link to comment Share on other sites More sharing options...
Ten Hammers Posted February 18, 2007 Share Posted February 18, 2007 I must admit the crack is hard to see, yes. If you could please also include a full pic of the vise it would be helpful. PERHAPS if you took a new Sharpie and marked the crack, the contrast would help. This will burn away if repairs are done. I would not use paint pen. Things like this may sometimes be repairable with brazing. Does the vise function as-is ? If so, close the jaws for a pic too please. Then also "lightly" clamp something like a piece of 2 "pipe and perhaps we can shed a light on things in this fashion. Don't put too much stress on it though. Good luck. Quote Link to comment Share on other sites More sharing options...
skunkriv Posted February 18, 2007 Share Posted February 18, 2007 Kinda funny place for a crack out in the middle like that. Might be right where the threads end. Need to see both ends of the crack. Back the screw clear out and slide the sleeve out the back of the vise. You would want to drill a hole, maybe 3/16 or so at each end of the crack to keep it from cracking more, even if you decide to braze it. Brazing would be the safest fix but just drilling the holes might be enough. Quote Link to comment Share on other sites More sharing options...
olfiar Posted February 18, 2007 Author Share Posted February 18, 2007 Yes, it seems to still function properly I just don't want the crack getting any bigger than it already is. I traced it with a black pen to make it a little darker. I tried to pull it out but it didn't seem like it came out. Quote Link to comment Share on other sites More sharing options...
skunkriv Posted February 18, 2007 Share Posted February 18, 2007 Just turn like you are opening the vise and keep turning, the screw will come out in your hand (not on your foot!) and then the sleeve will pull right out of the back. Clean it up some with a wire brush and take the sleeve outside to shoot the pic, better light. Quote Link to comment Share on other sites More sharing options...
Brian C. Posted February 19, 2007 Share Posted February 19, 2007 A friend recently repaired the jaw on a large anvil for me. He took a thin glade on an angle grinder & opened the crack up a bit, pre-heated the area, made a pass with a regular all-purpose welding rod, then a top pass with a hard facing rod. Then laid it, jaws side up on the wood stove for a slow cool down. Just a suggestion. :) Quote Link to comment Share on other sites More sharing options...
