macbruce Posted November 21, 2011 Share Posted November 21, 2011 Take an old bandsaw blade that is still sharp but doesn't cut strait........Cut it up into desired lengths, weld the ends and back if you wish with the teeth facing the same direction an bingo! Great for hot or cold..... edit....If you weld in a number of spots along the back you'll get convex cutting face..... Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 22, 2011 Share Posted November 22, 2011 As bandsaw blades often get tossed before they are worn out due to breakage I cut them up for hacksaw blades and in general I mount a piece in a wood cutting bowsaw frame---I punch the holes slightly inboard so they will tension a bit more than a wood cutting blade. Having a 30" hacksaw really helps when you are in un-powered situations. I usually have one tossed behind the seat of my pickup. The ones not suitable for hacksaw blades tend to get assembled into pattern welding billets alternated with pallet strapping. A bit tricking to get the first welding run in but starting with 25 layers cuts down on the runs needed to get a nice number of layers! The bandsaw blade etches bright too because of the nickle in them. Quote Link to comment Share on other sites More sharing options...
MattBower Posted November 22, 2011 Share Posted November 22, 2011 Reminds me of a shinto rasp. I have tried to figure out how to make a shinto rasp from hacksaw blades, but none of the methods I come up with end up looking more attractive than just buying one. Your method is simple, but probably not quite as clog-resistant as the originals. Quote Link to comment Share on other sites More sharing options...
Ironman50 Posted July 3, 2012 Share Posted July 3, 2012 Now i know where my broken band saw blades should go. Quote Link to comment Share on other sites More sharing options...
