Anvil Stand for 30" of railroad track?
I've recently acquired about 30" of railroad track which I intent to stand on end and use as my second anvil.
Any suggestions as to how I should fabricate a stand for this?
A couple timbers (2x4 or bigger) and some large U bolts. I expect you plan to replace this with a different anvil at some point, so durable but not permanent is the idea.
Phil
Phil
It's my second anvil - anvil #1 is a london pattern anvil of unknown make and is securely chained to a stump. This one will be used for demonstrations and for when my son is hogging anvil #1 (we all should have such problems).
Stick it in a bucket of concrete would be my suggestion.
I am sticking with durable but not permanent. There will be more anvils.
Phil
i am also looking for a Railroadtrack stand but i have the feeling that concrete would make my neigbours ("house-in-a-row") upset with the noise.
I do have a 40x40cmX1,3m (1x1x4 feet?) hard-solid piece of wooden beam to use but i dont know how best to "strap" the roadtrack to the head of this beam.
Anyone here having some suggestions to get it nailed down without having to drill a hole through a railroadtrack? (would be a pain for the drill(s) and time i'm afraid)
Whatever you do, it would still be better than what most 3rd world smiths use for production.post-114-0-94730900-1317209715_thumb.jpg
The bottom web should drill just fine, it won't be work hardened, but will be tough.
You can use U-bolts or band clamps around the whole thing, or you can forge some strap (say 1/4 x 1 hot roll) to make something that can have the slack taken up with a couple 1/2 inch nuts and bolts.
Phil
  • 2 months later...
you could always nail it down with some rail spike. a guy i forge with did that and hes been bangin away on it for so long now that he wont buy a real anvil.
Pound it into the ground?
