RyanErnst Posted July 10, 2011 Share Posted July 10, 2011 sorry if this is blazed everywhere i never really seen anything on this but i have a question, now isnt there coal forges and then forges for other fuels? my question is would charcoal or another fuel work in a coal forge or vise versa, does it matter what the forge is if it works and what is the difference between the two, i've seen quite a few but i dont know the differences, when i make a new one i want it to work the best it can, thanks in advance Quote Link to comment Share on other sites More sharing options...
John B Posted July 10, 2011 Share Posted July 10, 2011 There are forges/hearths for all types of fuels, gas, oil, solid fuel(coke/coal/charcoal) Each can be made specific to a)The fuel being used b)The type of work being done, They can be bottom blast or side blast There are as many recommendations as there are 'blacksmiths' for depths of, and types of, hearth designs. All need an air supply which is controllable. For your situation, which fuel is easily and regularly available to you? Decide what typ of items you will be making, a blade makers requirements is different to a general 'smith or other specialist area of smithing You can use different fuels in the same hearth, but some will work better than others, and each have their own peculiarities as to how to use them most efficiently. Browse the forges forums and see what suits you, they are as simple or complicated as you want to make them, and many 'smiths have more than one to suit what they are heating. Using different fuels in a hearth is always going to be a compromise, but it can be done. Quote Link to comment Share on other sites More sharing options...
RyanErnst Posted July 10, 2011 Author Share Posted July 10, 2011 thanks for the info, i use charcoal but im gonna have to look more into these then i thought, i didn't know you could use corn either that sounds kinda strange, and currently i like doing small ornamental work so i dont need better specifics then mabye a bladesmith but im sure ill make some of those too for awhile i just want to keep trying new things as i havent done a whole lot. anyway thanks again sorry to take up all your guys' more interesting thread space =p Quote Link to comment Share on other sites More sharing options...
RyanErnst Posted July 10, 2011 Author Share Posted July 10, 2011 thats quite alot of coal you get how long does that last before you need more?, and that sounds interesting i never thought of beatin a bag with a hammer to make better fuel :3, oh and i kinda gotta another question if one would be so kind, as i use charcoal it's generaly made in prity large chunks well how big do i want these chunks before i fire them up? im sure it differs to some exctent depending what im doing but in general whats a best average fuel size for charcoal, or anything of the sort Quote Link to comment Share on other sites More sharing options...
RyanErnst Posted July 10, 2011 Author Share Posted July 10, 2011 thank you, that should help i been useing it about the size of 3-4 walnuts besides when it burns down a bit :3 Quote Link to comment Share on other sites More sharing options...
