pkrankow Posted June 24, 2011 Share Posted June 24, 2011 So I was unhappy with my grate for my brake drum forge, a sewer drain. I also plan to clay the drum to eliminate the sharp corner and make it easier to remove clinker. So I also had a brain fart clear and realized that I had some 1/2 inch square and a gas forge. about 20 minutes later (including setup on the driveway and clean up: this is brought to you by the letter e and the number 0 Phil Quote Link to comment Share on other sites More sharing options...
musk-rat Posted June 24, 2011 Share Posted June 24, 2011 Looks nice. Very similar what I have in my forge now, just made out of rebar. Quote Link to comment Share on other sites More sharing options...
pkrankow Posted June 24, 2011 Author Share Posted June 24, 2011 Using an 18oz disposable cup I mixed up 3 parts sand to 1 part Portland (now whatever will I do with the other 93 1/2 pounds of this Portland) and ended up with close to twice what I needed for this 200mm x 50mm brake drum from my Chevy Caviler. At least I was able to get a busted bag for $1. I wrapped the grate in a bag because I think I want it removable... maybe? Good idea, bad idea? Doesn't matter? It seems I did a good job at rounding up the outside as it seems to be only about 1/8 inch out of round as I twist it in place. Phil Quote Link to comment Share on other sites More sharing options...
pkrankow Posted July 9, 2011 Author Share Posted July 9, 2011 I tried it today, and it worked WOW! until I went to clean it. Rake hooked into the grate and pulled it out like NOW! Then my fire dumped down the tue and ash trap...then I had to use a rod to clean the tue because it is only 1 1/2 inch diameter...Oh the comedy! I guess I need some stove cement or something to put the grate down permanent-like. I am out of portland because the broken bag I bought broke more so I spread it into the gravel of the driveway. It was already mostly spread when the bag finished giving out. Phil Quote Link to comment Share on other sites More sharing options...
