May 26, 201115 yr This is the new folder i made last week. patterned after the japanese higonomaki but with some extra work. The case is brass sheet chased with a pattern (that i freehanded), chiseled in using butcher chisels, a small flatter, a small X stamp, and a pointed nail for the stippling. The blad is a scrap of sawblade off the bench, and the copper pin is telegraph wire. any opinions or suggestions welcome. Ed Steinkirchner
May 26, 201115 yr Author the dimensions are: the length of the brass- 3 1/4" the brass width- 11/16" OAL length closed- 4 1/8" OAL length open- 6" blade- 3" point to pivot cutting edge- 2 1/8" blade at widest point- 3/4" blade thickness- 1/16" OAL thickness 1/8" the "tang" is 13/16" inside and about 1 1/4" on the spine side the pin is 3/16
