Stormcrow Posted May 17, 2011 Share Posted May 17, 2011 This one is ready to be picked up by the customer. He's clearing a section of his property, which is heavily covered in cedar and briars. This will be seeing action in that regard. The blade is around 16" long, with an unsharpened false edge. The steel is brand new 5160, multiple hardened in veggie oil prior to multiple tempering cycles. Handle is wrapped in hemp cord with cotton cord double Turk's head knots at the ends, all sealed with black shellac. Since briars were a major reason for the commission of the machete, the design is pointed more toward slashing than the short, recurved machete with a scabbard I posted recently. It'll still chop like an ax, don't get me wrong! A look at the socket prior to being wrapped: It's built for a righty, with the seam toward the fingers. A closer look at the end of the socket which is rolled over: I always enjoy making a good using tool. There are subtleties in physics and biomechanics that have to accounted for that cannot be understood fully unless you use tools yourself. And using a good tool like that is an especial pleasure as well. They just kind of sing to you is the best way I know to put it. Quote Link to comment Share on other sites More sharing options...
ianinsa Posted May 18, 2011 Share Posted May 18, 2011 I like that Pirates of the caribean look! mean knife. Ian Quote Link to comment Share on other sites More sharing options...
Cody Posted May 18, 2011 Share Posted May 18, 2011 I like It. How thick is it? How heavy is it? I like the handle, seems like it will be rugged and not slipand I also like the weight forward design. I'm sure he will be pleased! Quote Link to comment Share on other sites More sharing options...
Stormcrow Posted May 20, 2011 Author Share Posted May 20, 2011 It's already gone, so I can't measure it for you. I'd sayit averages a bit over 1/8" thick at the spine, though there are multiple distal tapers going on. It's heavier than a commercial machete of the same size would be, but it'll outperform it chopping while still slashing nicely. This slashed through tiny whippy branches about the size of a thick needle - cut, not ripped through them. Quote Link to comment Share on other sites More sharing options...
