June 12, 201115 yr Author Well watch this space. Im now in the process of packing up my shed to move house so this is on hold for about 4-6 weeks. Hope to get back into it as soon as possible.
June 12, 201115 yr I would drill a hole near the top to funnel dry sand in. Packing is not necessary. Put a bolt or pipe plug in to "seal" it. Have the feet big enough to put stakes through to anchor the stand permanent like, or provide better footing if you are on a soft surface. The larger foot will also prevent sinking on a less than solid surface. Phil
