turbo7 Posted February 9, 2015 Share Posted February 9, 2015 That movement is what you need to take out with the adjusting, there is a lock nut and a cone nut at each end, tricky bit is you need to make a thin open-end spanner (so do I) to hold the cone nut while you do the lock nut up, mine has same problem, has been apart for a while, let me know if i can help anymore Quote Link to comment Share on other sites More sharing options...
