pics I hope
Nice work. I like the design. They really work with the wood. Thanks for sharing. Good job. :D
Very nice Phil. Now that you got the picture posting down how bout showing more of your work?
Those are great handles/pulls! How did you make them? Did you drift the twisted piece ends and press the rosettes through the hole to act as the standoff and for fasteneing? As thomas said- SHOW MORE :D
Thanks guys. After I did the twist I off set the die on power hammer and flattened the ends. Then drill 5/16 holes.
The rosettes are 5/16 hex head bolts 2 1/2 in. long. had a bolster centered in flypress & flattened the head to 1/8
in. on all 8. Next stil in press took heat chiseled 3 lines across corners. next heat with ball end punch once in
center once between each chisel line. power brushed while hot burned on bees wax. spacers are 5/8 in. of 1/4 in black
pipe, look close you can see spacers in pic. Took 1 1/2 hours to make all 4 sets.
post-3508-0-01617300-1293848918_thumb.jp
