farm or compressor motor for hyd press
Finally giving in and building a hyd press using 2 stage log splitter type pump. Looking for a 3 hp 220v 1ph motor but I don't know which type motor is best for this application. Open to all advise...thx, Keith
The main thing is that you get a 3600 rpm motor if you are using a splitter pump.
  • 1 month later...
3600 rpm is key. Compressor motor is fine (has capacitors for extra starting torque) but not necessary. Hydraulic circuit doesn't have much load at startup since the valve spool is open to return line--could use a standard motor. You going w/ a 11 gpm pump?
Bill
