48willys Posted November 27, 2010 Share Posted November 27, 2010 I got to looking at some pictures of some industrial wood splitters and it has me wanting to build one of those 6 or 8 way wedges for our wood splitter. Our hyd splitter is more than big enough to handle it, but also it brings up the problem of building something like this that won't bend if we get something too hard in it. Anyway just was trying to find someone that has built one of these and might have some ideas (or plans) for a strong one. Also what would be the best angle to cut the wedges at so they don't jam? Quote Link to comment Share on other sites More sharing options...
clinton Posted November 27, 2010 Share Posted November 27, 2010 Out here the wood that we get does not have a straight grain, lots of knots and burls in it, so the best wedge here is just plain ol single type, and they work much better when they are affixed to the end of the splitter beam as opposed to being attached to the moving ram, when a log gets stuck on the ram you have to strip it off if it gets stuck on the wedge that is welded to the beam you can just throw another log in and drive it through Quote Link to comment Share on other sites More sharing options...
arftist Posted November 27, 2010 Share Posted November 27, 2010 What diameter is your cylinder? I would consider a four way first, even if you have the 5" cylinder needed for a 6 way or the 6" cylinder needed for an 8 way. Idealy the wedge should be real sharp for the first 3 or 4" the widen right out. Quote Link to comment Share on other sites More sharing options...
48willys Posted November 28, 2010 Author Share Posted November 28, 2010 I didn't go out and check but I think it is a 5" cylinder.If I did build a 4 way, what would be the least amount of material for the wedges(measureing from the cutting edge to the back)?I'm thinking of like 8" of 1" steel,do you think thats too much or not enough? Quote Link to comment Share on other sites More sharing options...
arftist Posted November 28, 2010 Share Posted November 28, 2010 1"x 4" should be good. Nice if you could weld a set of wings off the back to pop em apart. 1/4" plate for the back part. If you can, make the unit slip over your single wedge. Twisted, or notty or elm may not go through the four way. Also it is a good idea to have the vertical cutting edge a couple inches ahead of the horizontal. If you really want the lowdown on wood splitters, check out Hearth.com Quote Link to comment Share on other sites More sharing options...
pkrankow Posted November 28, 2010 Share Posted November 28, 2010 http://www.northerntool.com/shop/tools/product_200326298_200326298 http://www.northerntool.com/shop/tools/product_28657_28657 these? Phil Quote Link to comment Share on other sites More sharing options...
48willys Posted November 29, 2010 Author Share Posted November 29, 2010 Thanks for all the help.I went out and checked and it is a 5" cyl. I'm going to rework it with a push foot on the ram and the wedge at the end of the I-beam.That way I can make a quick change 4 way and maybe a 6 way that can be slipped over the wedge and locked with a pin. Quote Link to comment Share on other sites More sharing options...
