Alex Posted November 2, 2010 Share Posted November 2, 2010 I came across a rather heavy duty cast iron sink at work today in the garbage area and was wondering if it would make a decent improv firepot. It seems fairly thick, perhaps 1/4". I also say cast "iron", but is there any way that I can be sure it's not a monkey-metal zinc alloy or something? I was also wondering if a large, thick, cast iron skillet would work. I've read/seen that a lot of people use brake drum forges, but these are readily available and I'm just panning out my options. I would be forging mostly with charcoal, but possibly coal as well. Does one have to worry about cast iron forges cracking due to heat/stress? Any thoughts or info would be appreciated. Thanks, Alex Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted November 2, 2010 Share Posted November 2, 2010 Back in the day popular mechanics had an article using a cast iron double bowl, one Bowles the forge and one as the slack tub. This year they revisited it with a stainless steel sink. The original article is floatin around the net but I can't remember wear. I say go for the cast iron sink. Rivvit forges Whern't eany thicker. Quote Link to comment Share on other sites More sharing options...
Alex Posted November 2, 2010 Author Share Posted November 2, 2010 Thanks Charles. After a quick search I did find a load of examples of people using cast iron sink forges, including the double sink design. Here's an old school one in case anyone is interested: http://www.vintageprojects.com/metal-welding/shop-forge.pdf Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted November 2, 2010 Share Posted November 2, 2010 I was just going to post that link, but I read the rest of the new posts befor searching threw my links file. Glad you found it. Quote Link to comment Share on other sites More sharing options...
