glilley Posted August 27, 2010 Share Posted August 27, 2010 Making a replacement mailbox stand with post being 1" square solid and the cross bar (what mailbox will sit on) 1" x 1/2", all A36 using mortise/tenon construction. I have already punched/drifted the post 1/2" square to form the mortise and I intend to upset the 1" X 1/2" cross bar where it will join the post to create a good shoulder and butcher/swage part of it down to a 1/2" square tenon. Now, I know the tenon needs to be 1.5 times the length of the mortise (1" post so 1.5" in this case) but how do I determine what the dimensions of my upset need to be in order to provide enough material to draw out a 1/2" square tenon 1.5" long and still leave enough of a shoulder to provide support against the post? I feel confident I can eyeball it or get some clay and work it out but is there a formula one can use to determine dimensions of upset for size/length of tenon needed? Thanks! Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted August 27, 2010 Share Posted August 27, 2010 Cubic inches of steel = cubic inches of steel, fudge a bit for scale losses. Quote Link to comment Share on other sites More sharing options...
Don A Posted August 27, 2010 Share Posted August 27, 2010 If I'm following your question, and considering Thomas's reply, you would need 3/4" of .5 x 1" to render a .5 x .5 x 1.5" tenon. .5 X .5 X 1.5 = .375 (target) 1 X .5 X .75 = .375 (beginning dimension) Correct? Quote Link to comment Share on other sites More sharing options...
glilley Posted August 27, 2010 Author Share Posted August 27, 2010 Thomas and DonPowers - This looks like what I'm looking for. Looks like you determine cubic inches of desired result (.5 * .5 * 1.5) and reverse engineer where you maintain the width of the stock and plug in appropriate values for the other dimensions. Thanks! Quote Link to comment Share on other sites More sharing options...
glilley Posted August 27, 2010 Author Share Posted August 27, 2010 Sorry - ...maintain the width and height of stock and plug in appropriate depth values. Quote Link to comment Share on other sites More sharing options...
