Anvil Identity?
I just ran across anvil made by Ross Meehan Foundry In Chattanooga Tn.Anyone know anything about these??
Thanks
Mark
Thanks
Mark
Most of the ones I have seen that said foundry on them were advertizing pieces. Any guess on size or weight?
Ken.
Ken.
Around 100 lbs! Haven't got it home yet.
Around 100 lbs! Haven't got it home yet. It's kinda rough but I'll fix it!LOL!It was a steal!
I'm guessing cast iron due to the edge damage, How do you plan to fix it?
from WIKIPEDIA
Meehanite is a trademark for an engineering process to make many types of cast iron. When a foundry advertises that produces "Meehanite Iron" this means the foundry is licensed by Meehanite Metal Corporation, initially of Chattanooga, Tennessee but now based in Mequon, Wisconsin. The Meehanite process includes a series of specific processing steps, which, when followed, will produce (according to Meehanite) cast iron with uniform soundness, consistent physical properties and dependable performance in service[1].
Meehanite metal specifications include a wide range of cast irons, including flake graphite types, ductile irons, austempered ductile irons, wear resistant irons, heat resistant irons and corrosion resistant types. Meehanite is not a specific alloy or material. While Meehanite lists all of these metal types in its grouping of specifications, all of these types of cast irons can and are made by non-Meehanite licensed foundries. Many of the types of engineering grades listed by Meehanite were discovered or developed by other companies
Frankly it's probably better as a display piece than an anvil.
from WIKIPEDIA
Thanks for all the tech INFO!! WOW!!! I just gave $50 for it so no big loss. I thought it would be a historic piece!LOL!
from WIKIPEDIA
Ross Meehan was the name of a foundry in Chattanoga Tenn. Now a tailgate market
Ken.
Nice to know the current status; but the original post said "I just ran across anvil made by Ross Meehan Foundry In Chattanooga Tn" so no need to re-state that part.
