junker Posted June 22, 2010 Share Posted June 22, 2010 i have an interest in making some pattern welded rings, but first i need to learn how to make a standard ring, if anyone can give me any advice on this it would be much aprecieated. Quote Link to comment Share on other sites More sharing options...
bigfootnampa Posted June 22, 2010 Share Posted June 22, 2010 The most applicable method that I can think of would be to cut rough (or smooth) discs from thick flat stock and then hot punch the middles out. You'll need a mandrel to refine the shapes and a sizing mandrel. You could also make some by forge welding strips or bar stock but if you could do that you probably wouldn't be here asking for advice. You could also experiment with some open ended designs that just wrap the finger or some that twine together to make the ring. Wrapped wire, brazed or silver soldered is another possibility. Slices from medium to heavy wall tubing are a possible way, though you'd have trouble making that up from pattern welded stock. If I were you I'd start with the open ends designs... they are not very viable in non-ferrous but steel is SO STRONG that they are reasonably durable designs if you keep the end tapers decently chunky and (for safety and comfort) softly round the tips. I have taught beginners to forge them in a few hours. Quote Link to comment Share on other sites More sharing options...
Francis Trez Cole Posted June 22, 2010 Share Posted June 22, 2010 I saw a guy that made a damasecus billet turned it on a lathe the bore out the center and cut off slices he made real nice stuff Quote Link to comment Share on other sites More sharing options...
peacock Posted June 23, 2010 Share Posted June 23, 2010 forge a ball flatten it a little, punch a small hole, drift to size, finish to your liking. You can change the patteren on the ring by turning the ball so you punch thur in different directions. Quote Link to comment Share on other sites More sharing options...
junker Posted June 23, 2010 Author Share Posted June 23, 2010 thanks for the info guys, that last one sounds really cool. once i get my forge back together imm try those out and see which one works best for me Quote Link to comment Share on other sites More sharing options...
