using a tomahawk drift
You really should drive the drift through the hole over a bolster plate, esentualy a plate if metal with a hole in it a bit bigger than the drift. I've always just used my hardie hole for large drifting. Its usualy about the right sise.
link removed at the request of anvilfire
heres an example of drifting out a hole so you can visualise it.
I generally work the eye hole to the correct size with a bull pin and then switch to the hawk drift for the final shaping---of course that's because I have a stack of bull pins I have bought for US$1-2 and only the single hawk drift that cost me US$20...
I too drive the drift in over a bolster plate and then hammer on the sides with it on the anvil to expand and shape them.
Thomas
