HWHII Posted April 9, 2010 Share Posted April 9, 2010 I have aquired a low pressure 2 way cylinder 4" dia. with a 20" stroke. I was told it will produce 20 ton at 2200 psi. Is it possible to use this type of cylinder in a forging press? Thank you. Quote Link to comment Share on other sites More sharing options...
Nakedanvil - Grant Sarver Posted April 9, 2010 Share Posted April 9, 2010 Actually at 2200psi a 4" cylinder will produce 13 ton. Don't be fooled, a fast 13 tons can do a lot of work. Just like using a small power hammer, you need to concentrate the force, Luke! Quote Link to comment Share on other sites More sharing options...
HWHII Posted April 10, 2010 Author Share Posted April 10, 2010 Thanks for that info Master Jedi! Do you have any suggestions on what type of pump I might use with this? I have a OTC 2 gal. foot air pump which would work but I am worried about over loading it, even with a gage on it. I would like it to work in both directions so I can drift with it. Quote Link to comment Share on other sites More sharing options...
Richard Furrer Posted April 10, 2010 Share Posted April 10, 2010 Thanks for that info Master Jedi! Do you have any suggestions on what type of pump I might use with this? I have a OTC 2 gal. foot air pump which would work but I am worried about over loading it, even with a gage on it. I would like it to work in both directions so I can drift with it. You can set the pressure on most pumps with a turn of a screw. The "standard" practice on blacksmith forging presses outside of industry are log splitter pumps. I suggest you get the book by Jim Batson on building a hydraulic forging press. The motor/pump/other calculations and parts are explained rather well. http://www.dfoggknives.com/hydralic.htm Ric Quote Link to comment Share on other sites More sharing options...
Nakedanvil - Grant Sarver Posted April 10, 2010 Share Posted April 10, 2010 You can set the pressure on most pumps with a turn of a screw. The "standard" practice on blacksmith forging presses outside of industry are log splitter pumps. I suggest you get the book by Jim Batson on building a hydraulic forging press. The motor/pump/other calculations and parts are explained rather well. http://www.dfoggknives.com/hydralic.htm Ric I've not seen a pump like that, usually the valve has an adjustable pressure relief. The unit HWII has is a 5-10,000psi similar to an Enerpac I think. You better get a guage, but you'll probably be watching the work. Quote Link to comment Share on other sites More sharing options...
Mainely,Bob Posted April 10, 2010 Share Posted April 10, 2010 That has been my experience also,the relief valve is what we adjusted to get more pressure. Most of my experience comes from hydraulics powered by a gas or diesel engine so there`s plenty of power. Are there any dangers I need to be aware of when doing this with a limited HP electric motor? Quote Link to comment Share on other sites More sharing options...
HWHII Posted April 10, 2010 Author Share Posted April 10, 2010 You can set the pressure on most pumps with a turn of a screw. The "standard" practice on blacksmith forging presses outside of industry are log splitter pumps. I suggest you get the book by Jim Batson on building a hydraulic forging press. The motor/pump/other calculations and parts are explained rather well. http://www.dfoggknives.com/hydralic.htm Ric Thanks Ric. I do have the book but I was hoping for something simplier. Quote Link to comment Share on other sites More sharing options...
