Question on Glass Fireplace Doors
I have been asked to do a set of fireplace doors with glass inserts. Can anyone advise the best glass to use and any other tricks or tips? I've done a lot of fireplace screens but they all had wire and this will be my first time with glass.
Thanks, Hollis
I've used glass several times just regular old tempered glass.
I just build an angle iron frame for the glass to slide into then shim so it won't rattle or drill and tap and use a set screw( just don't over tighten or POP)
good luck Marc
  • 2 weeks later...
go to a glass supplieror glazier as there is a special heat resistant glass for this application. I had to replace the glass in my slow combustion stove andthey supplied me with a piece cut to size. From memory it was not expensive either
I don't know a whole lot about glass but a couple years ago the small glass window (approx. 9"x7") in my woodstove door cracked, no big deal...I have two glass company's within 15 min. from me and 4 stove and fireplace stores within a 1/2 hour, all the stove places told me to call the glass places, the first glass place said they didn't have it but could order so I called the second place and they were like, no problem how big do you need it ( I though great finally after a 1/2 hour of phone calls, the place that was 2 min away from where I worked have it!!) so I give them the dimensions and he say's is that all, no problem we got that, yeah that's all, how much is it? $90 :o !!! When do you want to pick it up? he says'
I had to ask twice, I still think he was trying to sell me a windshield for the space shuttle.
So I now have a woodstove with a very nice looking piece of plain old 1/4" mild steal plate in place of the window, it cost me zero $$'s as it is from one of my many supply pile's out back and took me about 10 min. to cut and paint black with high temp spray paint.
That's what I know about fire rated glass.
welder19
Nome
Mi Stato e chiesto di tariffa Una serie di porte camino con inserti in vetro. Chiunque puo Consigliare Miglior Il vetro da usare e eventuali Altri Trucchi Suggerimenti O? Ho Fatto ONU Sacco Schermi di Camino, ma "tutti" avevano filo e this SARÀ la mia prima Vetro Il Volta con.
Grazie, Hollis
[/ Quote]
Hello there are 2 types of glass:
1) Temperate of up to 400 °
2) The other here in Italy called "glass ceramic" has a heat resistance of 800 °.
In both cases the iron is fastened with a minimum of tolerance to avoid damage to the twist of iron, you have several options for mounting the cheapest and perhaps the miles is to use silicon at high temperatures.
Thanks to everyone who commented. I talked to a local glazier and he said tempered glass would likely work fine. I'm going to make a track for the glass to fit into so it is not under pressure when heating. We'll see what happens... :)
