February 17, 201016 yr how do you carve symbols and shapes into brass for things such as pommels and crossgaurds?
February 18, 201016 yr Engravers use tools like the ones in the picture. Others "chisel" in the features with various shaped cold chisels. I haven't much experience in either but I'll bet someone in this forum does
February 18, 201016 yr Dremils, chisels, drills, needle files (and other files). A lot of fancy ones are cast using the lost way process where you carve the wax positive---a lot easier than carving brass
February 18, 201016 yr You can also acid etch in the symbols you want. http://steampunkworkshop.com/electroetch.shtml Also like Thomas said you can use the lost wax casting method or a more direct approach is sand casting but the detail isn't as fine. Here is a series on steam casting a variation on lost wax casting used mostly for smaller items http://www.myheap.com/book/chapter-08A/steamcasting.php
