January 5, 201016 yr I've been screening my coal to cut back on the dust that chokes my fires and clogs my air. I was wondering if anyone knew of a use for it? Seems like a waste to toss it.
January 5, 201016 yr I collect my fines, wet them and make them into small "bricks" which I burn in the fire.
January 5, 201016 yr I make a slurry from fines and cap my fire leaving a cave door in the front when I weld. It's like a very big torch that you can't stand in front of when you add some air.
January 5, 201016 yr I make a slurry from fines and cap my fire leaving a cave door in the front when I weld. It's like a very big torch that you can't stand in front of when you add some air. Jerry, Do you just use it a bit like adobe to seal up the top of the cave? Thanx
