nc_cooter Posted September 2, 2006 Share Posted September 2, 2006 In a previous post you mentioned using Sikaflex 11Fc to mount your anvil to a steel plate. Could you explain Sikaflex ? Is it a silicone based product? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Hofi Posted September 2, 2006 Share Posted September 2, 2006 Hello Mike Sikaflex 11 fc pu base glue. I use the Sikaflex to glue the handles to the hammer head also. U can go on '' Sikaflex usa " and you will find many other polyurathane base glues. And I think to day they have a stronger one that I can not get in Israel. May be in the USA look for Hra50 If you want in the future to be able to take the anvil apart from the base, smear the anvil with a very thin layer of any oil. From the point of view of the noise it will work the same. Hope it is clear . Thank you for asking Hofi Quote Link to comment Share on other sites More sharing options...
Glenn Posted September 2, 2006 Share Posted September 2, 2006 Sikaflex-11 FC Description Sikaflex-11 FC is a one-component, gun-grade, adhesive and sealing compound of permanent elasticity. This dual-purpose material is based on a special moisture-cured polyurethane with an accelerated curing time. Advantages * Excellent adhesion on all cement-based materials, brick, ceramics, glass, metals, wood, epoxy, polyester, acrylic resin, and plastics. * Fast cure rate. * Good weathering and water resistance. * Non-corrosive. * Can be painted over with water, oil, and rubber-based paints. (Preliminary tests recommended). * High durability. Coverage 10.3 fl. oz. cartridge seals 12.4 lineal ft. of 1/2 x 1/4 in. joint.Sikaflex-11 FC Technical Information Sheet in pdf formatSikaflex11fc Material Safety Data Sheet in pdf format Quote Link to comment Share on other sites More sharing options...
Glenn Posted November 6, 2007 Share Posted November 6, 2007 According to the manufacture of the product (Sika), the shelf life is 9 months, because of the fast cure properties of the product. A quick search found 10 sales/distributor locations in Virginia and 6 in North Carolina, 16 in Texas, and 45 in California. They have over 200 distributors in the USA. Contacting one distributor at random they said they order it as needed and directly from the company (Sika) with a 3 week delivery time. This would leave over 8 months of shelf life when received. This distributor would sell to anyone, no open account needed. Quote Link to comment Share on other sites More sharing options...
