poseyforge Posted November 5, 2009 Share Posted November 5, 2009 has anyone thought about or done any wire sculpture? if so I was wondering about techniques and such for making trees as well as some other ideas... I made two trees yesterday and they turned out alright. I will post some pictures and keep playing around with it. Quote Link to comment Share on other sites More sharing options...
beth Posted November 5, 2009 Share Posted November 5, 2009 yes hi poseyforge i have done stuff with wire its good for sculptures- you wont need any heat as you prob found out with the trees, you can twist up lengths of it for sturdier sections, wind it round itself, thread stuff on it, make topiary type frames and "infill" with like weaving or spider web kind of ways its just really versatile stuff. chicken wire is also good with wire either stretched over areas or scrunched up in tight shapes for dense looking areas. get some pics on! Quote Link to comment Share on other sites More sharing options...
beatamax Posted December 17, 2009 Share Posted December 17, 2009 When i've played about with wire i've found that the wire bends best without kinking if I pull it round the handle of my vice first, it needs to be kept tight while your pulling it. Hope you get what I mean I cant think how to describe it better. Quote Link to comment Share on other sites More sharing options...
Dodge Posted December 18, 2009 Share Posted December 18, 2009 Depending on what you are using for wire, and what you are trying to do, you may in deed need to heat it. I have been working on a sculpture using wire coat hangers and in many cases, I need at least the heat of a propane torch to make bends and twists. OK, not imperative, but twists stay better when heated to a red heat Not sure of the content of a basic coat hanger but they do seem to anneal when heated so they must have been harder to begin with. Hope this was helpful :D Quote Link to comment Share on other sites More sharing options...
Bleisle Posted January 7, 2010 Share Posted January 7, 2010 I at one point earlier created a 5 ft wire sculpture out of 50% recycled copper wire. My link is here and here is the link to a close up of the head. I haven't done alot of work on this sort of project in a long time, but it was alot of fun. i used only my hands and occasionally a pair of needle nose pliers. Quote Link to comment Share on other sites More sharing options...
