hot cutters ? I tried all yesterday afternoon to split a piece of steel ans ended up with a split about a milimeter long so some help would be nice
Heat steel to orange
place on cutting saddle or plate
place hot cut on piece
Strike with heavy hammer repeatedly re-aligning the cutter as needed.
Stop when red and re-heat
Now where did you go astray?
Note that for long cuts it helps to start them at an edge as having it cut through there first allows further in metal to curl away from the cut as it progresses.
yes I know that already.
I went wrong when I tried to cut it with out any of those listed tools, and an 8" piece of RR track as an anvil.
No disrespect intended, but if you "know that already", why did you ask for help?
Some jobs can't be done without the proper tools. 8" of railroad track is a paper weight, not an anvil.
Get a solid surface (anvil) and follow Thomas' directions. It works.
Don
Ya the only problem is getting an anvil ill try again today and see if the person is there, but what i was thinking was a modified swage or something like that idk
