October 27, 200916 yr OK I am looking for a coal forge cast. I have plans to build one from 1/2 to 3/4 by 6 or 8 inch wide hoy roll. Buy the time I Buy the material, cut, drill tap assemble. I would have more than the cost of just buying a cast fire box. SO who has a cast fire pot for sale. What companys still make and sell cast fire pots. Thanks. With a roof on my new building and a tire hammer almost built I want to get out of my rivet forge and into a full size unit asap. RalphAndrewKessler Georgia rakessler
October 27, 200916 yr look under brake drum forge thread I posted a design for one made from 1/4" plate. I have used one for the last 10 years works great and even if you bought all new stock a lot cheaper if you have trouble finding it I can send you a pdf on the design. here is a link to the thread http://www.iforgeiron.com/forum/f85/brake-drum-forges-14710/index4.html Edited October 27, 200916 yr by Francis Cole
October 27, 200916 yr I have fabricated one and I have also bought a Vulcan firepot from centaur forge. Both work well. The firepot I made was from this link MILD-STEEL-COAL-FIREPOT-Fabricated I hope that helps. John
October 27, 200916 yr There is one in the tailgating section:Firebox for coal forge Centure, buffelo. One with some thickness and life left in it. - Blacksmithing Classifieds Some of the discussion threads found using the search feature at the top of this page:http://www.iforgeiron.com/forum/f7/roger-lorance-firepot-swage-blocks-14434/http://www.iforgeiron.com/forum/f85/show-me-your-forge-solid-fuel-3899/http://www.iforgeiron.com/forum/f85/forge-building-advice-14160/http://www.iforgeiron.com/forum/f85/so-i-need-build-new-forge-13837/http://www.iforgeiron.com/forum/f56/making-firepot-8670/http://www.iforgeiron.com/forum/f7/centaur-vulcan-firepot-4527/http://www.iforgeiron.com/forum/f7/firepots-2827/http://www.iforgeiron.com/forum/f17/wanted-coal-coke-firepot-329/http://www.iforgeiron.com/forum/f7/fire-pots-543/ General Information:Blower, Firepot, HearthSteel s-draft drawing New firepots:Fire Pots
October 28, 200916 yr I'm going to suggest the Roger Lorance Fire pot. Its the last one you will ever buy. Unless of course you need another forging station....
