collijs Posted September 8, 2009 Share Posted September 8, 2009 Hello all! Bought a Champion 400 blower ($60- Score!) and am trying to remove the fan shaft/worm gear to replace the ball bearings. They are mostly frozen in place. 1)Have the fan and fan shroud removed but cannot get the rear nut (at the crank end) off to access the bearings. Is it reverse thread? 2) There is a seal/cap of some sort at the fan end of the shaft as well. Does this tap out or is it threaded? Everything has been soaked daily with "liquid wrench". Everything turns and works ok I just know it could be better and want to make it last another 100 years. Quote Link to comment Share on other sites More sharing options...
David Einhorn Posted September 8, 2009 Share Posted September 8, 2009 Here is a thread that discusses it. There are a number of threads on the Bearings in Champion 400 blowers: http://www.iforgeiron.com/forum/f11/champion-400-blower-8821/ Go to top of page and click on Search, then enter Champion 400. Quote Link to comment Share on other sites More sharing options...
collijs Posted September 11, 2009 Author Share Posted September 11, 2009 I researched all the threads fairly extensively before posting. Unless I missed them somewhere, I could not find answers to the two questions I asked. Any ideas? Thanks for your time. Quote Link to comment Share on other sites More sharing options...
Nakedanvil - Grant Sarver Posted September 11, 2009 Share Posted September 11, 2009 Now that's just way too confusing! "Threads" about "threads"? "There are a number of threads on the Bearings in Champion 400 blowers"! Wait, does he mean machine threads or conversation threads or............???????? Quote Link to comment Share on other sites More sharing options...
HWooldridge Posted September 11, 2009 Share Posted September 11, 2009 Both caps are threaded and should unscrew normally counterclockwise - they are not reverse threaded. I'd use channel-locks (gently) to break them loose. The cap nut probably has a cotter key so look for that. Let us know if you need any more help. Quote Link to comment Share on other sites More sharing options...
collijs Posted September 13, 2009 Author Share Posted September 13, 2009 Got it, thank you. The teeth on my channel locks were just eating the metal but it finally broke free. No cotter key seen. Bearings at fan end look good. I'll replace ones at back end soon. My wife and I are starting a day camp for foster children. We will be doing some blacksmithing with the kids. This will be our second hand crank blower. Again thanks--- Quote Link to comment Share on other sites More sharing options...
