Anvil Peter Wright ID
Hi
Has anyone seen a Peter Wright Anvil with a logo Carved in the side. If you look carefully there is a 1 marked on either side. There appears to be a B on the bottom even if it was an 8 which is 1 8 1 it does not match the weight of the anvil. Any help to Identify year of manufacture or other details would be appreciated.
Thanks
17192.attach
17193.attach
17194.attach
17195.attach
17196.attach
17197.attach
I have a couple P.W.'s and have researched them a bit, and my guess is, that the logo (cross in shield) was carved in by the purchaser, as were the B's stamped into the base. The center number of the weight stamp has been carved away, when making the vertical cross line.
The weight is in British Standard. The first #, 1cwt = 112 pounds, 2nd. # 1/4 cwt. = 28 pounds, 3rd. # is pounds. My main anvil is stamped 1 0 9 = 121pounds U.S.
Just something some owner has carved in the side. It's a good idea to mark your anvils for ownership---I've had a 200#'r stolen before. I mark mine on the bottom though less chance of a their removing the mark...
