Building a Shop
Poles, steel siding and open trusses ( height ) would be my choice. Slab floor with heat in it ( boiler outside ). Drywall lining over sprayed insulation or perhaps sheet foam. Wired in conduit. 200 amp service. Yes, skylights.
Matt, son, you got a nice shop there. Awful nice use of space and handy stuff you built too. I'm still in a 20' square garage after all this time ( 18 years in this shop ). Hope to build someday.
Thanks Guys. Yea that old saw has a full 36" throat. It's a little scary, running at 6000sfp. Came from an old foundry pattern shop. I need to get some kind of gard on it.
Matt.
  • 2 weeks later...
I converted my yard implement shed into my shop. It's a 12 X 20 wood frame structure with wood floor and not insulated. Double doors open up to 10 X 7 on one end and there is a passage door at the other end. I put up sheetrock on the walls and cement board on the floor to reduce the fire danger. I have my coal forge, welding machines, work bench, leg vise and various other items in there. In winter I heat with a kerosene heater. I buy a lot of my material from the local steel supplier and some I pick up at the transfer station for free. Most of the bought material comes in 20 foot lengths, so I bring tools and cut it in half so I can carry it in my truck. I've been wanting to build a power hammer but the wood frame floor won't take it and that might be crowding my space a bit. Until I had put up the smoke pipe, I had wheels on the forge and would roll it outside to work. That was okay until it rained or winter rolled in.
SIR,
new member here!
you can never have too much space. on a
different webiste they suggest you decide
what size you want, double it, and then add
30%. i have a 30X50 shop, and i wish it was
bigger!!
good luck to all.
wlbrown
wright city, mo.
